Search:
Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Using a heavier trick fork for everyday use
  1. #1
    Im getting a new frame and i wanted to get a trick fork (starfuckers fork), any disadvantages in doing so for day to day riding?
  2. #2
    Out of fucking control heavymetal's Avatar
    Join Date
    Dec 2007
    Posts
    13,739
    This should be in the trick forum.
  3. #3
    HoW do i move it?
  4. #4
    Out of fucking control reezy 2.0's Avatar
    Join Date
    Oct 2008
    Location
    BNA
    Posts
    4,181
    I'd say the only disadvantage is that you'd be able to barspin and do tricks.
  5. #5
    sugarkane
    Guest
    Quote Originally Posted by rhys View Post
    hahaah +1
  6. #6
    NJS Certified
    Join Date
    Oct 2008
    Posts
    104
    you cant run more that a 28c tyre if thats what your into.
  7. #7
    is it uncomfortable to ride cos its heavy?
  8. #8
    NJS Certified Cal M's Avatar
    Join Date
    Sep 2008
    Posts
    238
    No, the only potential problem will be awkward commuting geometry.
  9. #9
    My daily commute is 20km each way on a Charge Freestyler. The Charge geo is ok because the frame is designed around the fork but the extra weight is noticeable.
    What frame are you putting the starfacker forks on?
  10. #10
    gorilla zengang, should be alrite... i think
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
